Hi, my nexus 5 switches the screen on-off repeatedly while charging. It begun after the lollipop installation. Any ideas? Thanks!
Nexus 5 screen on-off while charging
6 commentaires
  • nov. 28, 2014 2:21 PM UTC
Hi there, the last update is indeed most certainly the culprit here as there have been reports of issues with Lollipop on Nexus devices. There isn't much that can be done until Google fixes these issues and releases an update. You can always do a factory reset and see if it helps (don't forget to do a backup first). Thank you! ________________________ If you see a good answer, give it a star.
  • nov. 28, 2014 9:52 PM UTC
Thanks a lot! Let's hope google hears us!
Just switch system language from "Francais-Canada" to anything else! This is just a bug with the language of the system. I've tested on "Francais-France" And "English- US" and there is absolutely 0 bugs with my N5
  • nov. 29, 2014 3:58 PM UTC
Thank you! Just switched it to français France and I'll put it on charge. I hope Google will address the issue though.
Did you already received your lollipop update? My sisters and brother in-law nexus 5s (they bought it on black Friday) didn't received android 5.0 update yet...anything to do to receive it? I've wiped cache from recovery but nothing..I manually flashed factory images since first developer preview of Android L and I already have my lillopop update since a few weeks...how to get faster OTA update on stock?
  • nov. 29, 2014 4:31 PM UTC
I got it something like a week ago. BTW, your language trick seemed to work, thanks a lot!
