Communauté
Répondu
Will my phone work with Koodo?
I was shopping online and found that phone:
BLU Studio Touch  4G_LTE Smartphone GSM. Unlocked.
It say about the network:
  • [b]4G LTE, (2/4/7/12/17), 4G HSPA Plus (850/1700/1900/2100)GSM Quad band: US compatibility Nationwide on all GSM Networks including AT and T and others
NETWORKTechnology GSM / HSPA / LTE
2G bandsGSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
[b]3G bands[b]HSDPA 850 / 1700(AWS) / 1900 / 2100
[b]4G bands[b]LTE band 2(1900), 4(1700/2100), 7(2600), 12(700), 17(700)
SpeedHSPA 42.2/11.5 Mbps, LTE Cat4 150/50 Mbps
GPRSClass 12
EDGEClass 12
it is possible for you to confirm me this phone is compatible with your service and on 3G or 4G_LTE... or both ?
thanks.
Meilleure réponse par Nabil Koodo 6 novembre 2016, 20:05
Hey Venom,
Most of the recent phones will work on the Koodo network (HSPA 850/1900 MHz frequencies and LTE Band 4 1700/2100 MHz frequencies) with a few exceptions. If you can have access to the IMEI, click here http://koo.do/1aU1u0o to make sure that your phone is compatible with our network. According to your post, this device will work.
Hope this helps!
Afficher l'original
1 commentaire
Niveau d'utilisateur 6
Hey Venom,
Hope this helps!
Commenter
